ASP pulley users please chime in
Old Oct 10, 2004 | 10:19 PM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Default ASP pulley users please chime in
I am looking at getting a used ASP 25% underdrive crank pulley with 3800 miles on it. It is $155 shipped with new bolt. I am having a cam put in sometime within the next month or so.
Would it be a good idea to get this (good for the money?).
How much power can I expect?
What are the possible problems?
Cajun
Old Oct 10, 2004 | 10:29 PM
gonbad's Avatar
gonbad
Maybe 8-10hp.
If it is used then it has already been stretched over a crank once therefore it may not fit as tightly the next time. This lead to the possibility of having it walk off the crank.
Either way if you have it apart and use a new pulley or a used one I would pin it for safety. I should have but didn't think of it in time.
Old Oct 10, 2004 | 11:02 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Yes, def get it. You have t remove the stock one anyway to get to the cam. well worth it to replace it with an ASP. I would also pin it.
Old Oct 11, 2004 | 09:47 AM
0Cajun @ Edgyvette
Former Vendor
what does pinning it involve? Is there a link showing this? Thanks
Cajun
Old Oct 11, 2004 | 10:32 AM
gonbad's Avatar
gonbad
Check with Patches or ask over on the Forced Induction area. You have pin the crank when using a blower. However it is recommended on any modded car for safety reasons.
Old Oct 11, 2004 | 12:27 PM
Mr. Jones's Avatar
Mr. Jones
about 8 hp, def pin it since its used. do you trust the original user, did they install it/remove it with a good puller on the center section. if this is unknown pass on it.
Old Oct 11, 2004 | 10:18 PM
2001 Red Coupe Bandit's Avatar
Yep, DO IT 100% if your getting a CAM. If your JUST putting on a Pulley then my vote is NO WAY!!!
I Have One
Old Oct 12, 2004 | 05:18 AM
SnowyATX's Avatar
SnowyATX
I bought a used one and the bore was all trashed...couldn't use it. Buy a new one just to be safe.
Old Oct 12, 2004 | 07:05 AM
Patches's Avatar
Patches
After the pulley failures I've seen when used pulleys are reused, I'd pass despite the $100 savings. Regardless of the age of the pulley, I highly recommend you pin it. Pinning keeps the pulley from spinning on the crank snout which, in turn, prevents the bolt from backing out. Andy at A&A might see his way to renting you the pinning kit. Otherwise, it's about 85 bucks from Magnusson for theirs. It's basically just a crank bolt with drill bushing drilled at the radius where the pully and crank snout interface. I'd put two pins in 180 degrees apart. Here's a pic of one we did on a buddy's car. We only used one pin on this one.
Old Oct 29, 2004 | 02:08 PM
0Cajun @ Edgyvette
Former Vendor
Got a new MTI underdrive crank pulley with belts. The guy ordered it for a 99 but it should work on my 2000 right?
Do I really need the alternator pulley?
Do I have to pin this new pulley?
Cajun
Old Oct 29, 2004 | 03:44 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
Cajun
Nope, if its new then just bolt it on.
Old Oct 29, 2004 | 04:15 PM
Jackal's Avatar
Jackal
I didnt really care about the HP because that is neglagable. I put mine on for the reliablility factor. I have heard too many stories of stock pulleys comin appart.
Old Oct 29, 2004 | 07:41 PM
Patches's Avatar
Patches
Cajun
You don't need the alt. pulley. I would definitely pin the crank pulley. That will prevent it from walking. I know it's new but I've heard of new ones walking off the crank as well. Pinning is easy. Install the pinning bolt, drill two .250" holes 180 deg. apart and insert the pins. Then install the pulley using the normal installation instructions.
Old Oct 30, 2004 | 12:39 AM
STEEL's Avatar
STEEL
Default hey
do you have to change the belts
To ASP pulley users please chime in
