easiest throw aftermarket shifter?
Old Oct 12, 2004 | 01:22 AM
Bullet's Avatar
Bullet
Default easiest throw aftermarket shifter?
Who makes the easiest short throw shifter out of all of the most popular? I don't want a hard shifter. Just want a more positive feel - not so lose as the stock, and a shorter throw.
Old Oct 12, 2004 | 12:42 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Hurst! all the way!
Old Oct 12, 2004 | 02:22 PM
Bullet's Avatar
Bullet
I drove a C5 with a Hurst - stiff as a board.
I'll probably just cut the stock shifter down about 3/4".
Old Oct 12, 2004 | 07:37 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
then it doesnt exist. your picky!
Old Oct 12, 2004 | 07:49 PM
camiv's Avatar
camiv
I have the Kirban and like it. It is quick and snaps in/out of gear much better than stock. Mine was a little stiff when new but after I broke it in ....I became happier. My wife can drive the car...that says it all!
Old Oct 12, 2004 | 08:38 PM
Derek Zalewski's Avatar
Derek Zalewski
Default Removing shift lever arm length (Cutting)
By removing 3/4" from the shift lever arm will give you minimal gains in shortening the shifter throw length.
Your efforts will go up slightly since you are effectively removing your torque advantage (by removing 3/4") with a longer shift lever arm.
Derek
Old Oct 12, 2004 | 10:07 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Originally Posted by eamador11
Hurst! all the way!
Use the softest springs that come with the shifter and give it two months to loosen up. Its an awesome shifter that I've used for a year now and couldn't be happier with it.
Old Oct 14, 2004 | 01:02 AM
Bullet's Avatar
Bullet
Where is the best place to buy a Kirban?
Old Oct 14, 2004 | 03:49 AM
VetteHunting's Avatar
VetteHunting
BPP comes with different spring settings and has a very short throw. Cant be shifting like a pansy though You do have to put a little effort into it. I like it, personally.
Old Oct 14, 2004 | 08:57 AM
bassvet's Avatar
bassvet
St. Jude Donor '10
personally like the B&M "ripper" just my .02
Old Oct 14, 2004 | 03:51 PM
Bullet's Avatar
Bullet
Where do I buy a BPP?
The wife needs to be able to do the shifty thing. If wifey gets p*ssed because of a mod, then must listen to on mods, as well as no mo "personal relations".
Old Oct 14, 2004 | 03:57 PM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
I put a Mallett shifter in my wifes '01. She has no problem with it. Nice easy shifts!!
Old Oct 14, 2004 | 05:22 PM
QuikZilver's Avatar
QuikZilver
I had a BPP shifter (bought it direct from Breathless, they give members a 10% discount, just tell them when you order that you are a CF member). I had to sell the shifter after 3 days in my Z. I had a major shoulder injury 6 years ago. Even with the softest springs, I could feel the muscles in my arm getting ready to tear when shifting into 5th, 6th and Reverse. The first four gears were fine. It may have loosened up after a while, but when I couldn't move my arm when I got home, it was time to put the factory shifter back in. It is a great product! Please don't get it wrong. If it weren't for my shoulder, I would still have it in there. It is a quality piece!!
Old Oct 14, 2004 | 05:40 PM
badc5r's Avatar
badc5r
Old Oct 14, 2004 | 06:33 PM
VetteHunting
The BPP is Breathless Performance Products. You can find their banner in the vendors list. They include a White spring set with their shifter that the BPP guy had dubbed the "woman" spring. I cant give input as I never changed my springs.
Old Oct 14, 2004 | 06:48 PM
LoneStarFRC's Avatar
LoneStarFRC
Also don't forget the Red Line D4 ATF in the trans. This also helps a lot too!
To easiest throw aftermarket shifter?
