Bad IAT
Old Oct 12, 2004 | 10:44 AM
cyclerage23's Avatar
cyclerage23
Default Bad IAT
I keeo getting a code for my air temp sensor. Does anyone have an extra one?
thanks
J
cyclerage23@yahoo.com
Old Oct 12, 2004 | 12:22 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
I may have one lying around because I replaced mine after getting an IAT code. Turned out the sensor was fine and it was the IAT harness that was bad. It's a fairly common problem. Do some searching and you may find something.
Old Oct 12, 2004 | 12:33 PM
5 Liter Eater
St. Jude Donor '11
Here's some examples:
http://forums.corvetteforum.com/show...ht=iat+harness
http://forums.corvetteforum.com/show...highlight=1111
9 times out of 10 it's the harness, not the sensor. The part number for the harness is in one of those threads.
Old Oct 12, 2004 | 01:22 PM
cyclerage23
Where does the replacement harness plug in? Or does it splice in close to the connector?
Old Oct 12, 2004 | 02:32 PM
5 Liter Eater
St. Jude Donor '11
It consists of the plug that the IAT sensor plugs into and about 12" of the wires that come out of that plug. You snip the IAT harness wires off about that far back and solder the new harness in/shrink wrap/etc.
Old Oct 12, 2004 | 03:39 PM
cyclerage23
thanks
Old Oct 14, 2004 | 07:40 AM
cyclerage23
Thats what it was, the wires were crack inside the insulation about an inch before the connector. I hooked up the scanner and could watch my air temp change when I would moved the wires around. Since it was so close to the connector, I just pulled the pins out of the connector, trimmed the wires back to a good spot and soldered the wires to the pins. slid the pins back in the connector and deleted the code. Problem solved!
thanks,
J
Old Oct 14, 2004 | 02:31 PM
5 Liter Eater
St. Jude Donor '11
Beauty! Glad I could help.
To Bad IAT
