Heads I win!!
Old Oct 12, 2004 | 07:39 PM
Irish Whiskey's Avatar
Irish Whiskey
Default Heads I win!!
Want to keep stock block. Making 304 rwhp -285 rwtq. If I add heads,228 or so cam, long tube headers, what power at the back wheels do you think I can get. Heard around 400 rwhp with LS6 heads. What about with the AFR 205 heads?
Old Oct 12, 2004 | 09:33 PM
blktie8's Avatar
blktie8
Default h/c
sent you an e-mail
Old Oct 12, 2004 | 09:39 PM
mdhmi's Avatar
mdhmi
360 - 390 rwhp. Just do a forged bottom-end, Stage IV or V tranny, and a TTi Stage II or Stage X TT kit and be done with it .
Good luck,
Mark
Old Oct 12, 2004 | 11:36 PM
Irish Whiskey
Mark,
Please decode for me what all the TT's and the Stages stuff stands for - Thanks!! Automatic will probably be reworked by Wheel to Wheel - new planetary gears, etc. Thanks again would like to see that 400 rwhp number come up!!
Old Oct 12, 2004 | 11:51 PM
Tsab's Avatar
Tsab
A good set of ported LS6 heads and decent cam and long tube headers will take you up to 400 RWHP without much trouble. Just my .02
Old Oct 13, 2004 | 07:16 AM
Fastbasser's Avatar
Fastbasser
400 thru an A4 is stout..
JMHO
Old Oct 13, 2004 | 07:49 AM
Mr. Jones's Avatar
Mr. Jones
I have a mild 224/224 .563 lift cam, ls6 heads mild porting, with stock valve size and stock compression, pulley, cut factory air box & stock exh. manifolds with z06 cat back this made 374rwhp thru 3.90 gears. with some Long tubes and Blackwing I should see 400+. the 228 cam with a higher lift should make 400+ if you use similar parts and get it tuned.
I have LGM long tubes, I am waiting for winter.
Old Oct 13, 2004 | 09:01 AM
Vector's Avatar
Vector
I have '98 A4 - Perf. Mods- Stage 2 LPE Heads. Long tube Belanger Tri-Y headers, 224/.581/114 Cam, Votex Air, Ported Throttle body, LS6 intake, Tri Flow Exhast, Yank/LPE 2800 TC, with dyno tune - 394RWHP, 364RWTQ. (3.15 Gears)
Underdrive pulleys would be another 5-7 RWHP.
Good Luck!
You'll love the power!
Old Oct 13, 2004 | 06:40 PM
blktie8's Avatar
blktie8
Originally Posted by Irish Whiskey
Mark,
RODNEY CRASHED 94
End of story!
John
Old Oct 13, 2004 | 07:02 PM
Irish Whiskey
John,
You mean the blue C4 you had a MIlan?
To Heads I win!!
