higher ratio rockers?
Old Oct 12, 2004 | 11:12 PM
MJD's Avatar
MJD
Default higher ratio rockers?
Say I switched out my stock rockers for some with a 1:85 ratio. By doing so could I get the performace boost of a mild cam? Would it be cost effective compared to installing a cam?
Old Oct 12, 2004 | 11:57 PM
IFLUBYU's Avatar
IFLUBYU
Only if you are paying someone else on the labor. If you do the labor yourself, the cost is about the same. Better power with a cam, but alot more labor. Either way you will want to get the car tuned by a pro when you are done.
Not an expert, just my $.02, good luck!
Old Oct 13, 2004 | 12:18 AM
MJD's Avatar
MJD
Thanks for the info. Anyone else want to through in their $.02 worth?
To higher ratio rockers?
