Do all C5 vettes have TC and AH?
Old Oct 13, 2004 | 09:32 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Do all C5 vettes have TC and AH?
Do they have both? Do all C5s have competitive mode?
Old Oct 13, 2004 | 10:01 PM
LoneStarFRC's Avatar
LoneStarFRC
No. Some have both and then again some only have Traction Control (like mine for instance). I think the "Competitive Mode" is only on those that have AH. HTH
Robert
Old Oct 13, 2004 | 10:12 PM
AFVETTE's Avatar
AFVETTE
No. They all have Traction Control, but Active Handling wasn't available until late in the 98 model year. Then it was a stand alone option until later in the C5's production run. I know on my 99 it was a $500 option.
At some point TC/AH became a standard feature. I'm sure someone will chime in.
Tom
Old Oct 13, 2004 | 10:18 PM
Shortimer's Avatar
Shortimer
My 2001 has the 2nd generation Active Handling as a standard feature. Prior to '01 AH was a $500 option.
Old Oct 13, 2004 | 10:20 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
All C5's have Traction Control.
Active Handling become an option (as mentioned above) in '98. It then became standard in 2001.
Competitive driving mode is only on cars with Active Handling, as this mode turns Traction Control off, but leaves Active Handling on.
If you don't have Active Handling, you can't exactly leave it on, so thus there is no competitive mode.
No Rice's Avatar
No Rice
I have a 2000 and I have the AH button on the console, but I did not know I can switch between different modes. I thought it was just on or off.
Old Oct 13, 2004 | 10:22 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
If you press and hold the button for 5+ seconds, you should see "competitive driving" appear on the DIC display. On a 2000, you must be at a stop to do this. On 01/newer cars, you can do this at any speed.
Old Oct 13, 2004 | 10:25 PM
No Rice's Avatar
No Rice
And whats the benefit to this vs. having it on?
Old Oct 13, 2004 | 10:37 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
You're controlling 2 different systems.
Competitive driving mode turns traction control off, but leaves active handling on.
Both are on by default everytime you start the car.
If you simply press the button,, you turn both systems off.
If you press and hold it (as explained above) to enter competitive mode, you turn off traction control (ie: you can do a burnout), but you also leave active handling on (which can still prevent you from totally losing control of the car if you get too wild or begin to slide). This is the preferred way to have a little fun, yet still have that safety net than active handling can provide.
To Do all C5 vettes have TC and AH?
