MTI Stealth I Cam-Vid clips
Old Mar 6, 2005 | 04:31 PM
Chrispy's Avatar
Chrispy
Is a stall converter necessary with the stealth 1 cam?
How is power down low?
What was done tuning wise for idle?
I was actually looking at a slight variation to the stealth 1.
A 220/224 115LSA/115ICL on XER lobes.
Anyone have an overlay of stock heads/cam dyno with stealth 1 dyno with stock heads?
Old Mar 6, 2005 | 05:44 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
MTI can answer your question regarding stall converter.
This cam is a mid-high range stick. Power comes on later rather than sooner, yet for a very mild cam, it does makes power! Idle was adjusted to 900 rpm by ECS.
I believe the stealth II cam is what you are looking for. LSA is 116 but I dontthink they are XER lobes.
