United Kindom Lights Conversion
Any GM/Corvette trained auto electicians out there?
I know this is mainly a USA site but I also know there is alot of knowledge out there and someone might be able to help or give some useful advice, so here goes.
I'm awaiting shipment of my 2000 C5 later this month from the USA. My Corvette has Nightlight Sentinel, DRLs, Active Handling, Selective Damping and a few other electrical gizmos etc.
As a car mechanic in my earlier years I was quite happy and confident to do the lights conversion work myself. I had worked out what lights and wiring to change and which to lose (DRLs). I als worked out that by ordering parts from the USA the cost would be around $900.
However, one of the American car specialist in the UK has said that if I do it myself and, in doing so, change the "resistances" of the wiring I could easily have an adverse or disasterous affect on the Active Handling etc. I am told that the cars computer needs re-programming to tell it the light configuration and operating method. If I let this dealer do the work it will cost $2800 plus UK Value Added Tax (17.5%).
Speaking to two other UK specialists I am told that, if the work is done correctly, there is absolutely no need to re-program. These dealers have quoted $3100+tax and $1500+tax to do the work. This has left me a little confused.
My question is - has anyone first hand experience of converting a C5 (with electical options like Active Handling etc) to UK specification and what is your opinion on the re-programming issue. Also, any idea why the quotes for conversion work might vary so widely?
Sorry this message is so long but I thought I could not explain my delema without a full description.
Any and all advise gratefully received.
Last edited by panrixx; Oct 14, 2004 at 03:24 PM. Reason: Additional request insertion
I need to know if making these alterations can affect the wiring resistance in such a way that it can screw up other electrical functions controlled by the cars computers (such as the Active Handling, ABS, Selective Damping etc).
Regards
Brian
You can disble the DRL's by pulling the #38 (I think) fuse. Do a search to find out the exact fuse and procedure.
The T-84 Euro spec headlights and wiring harness can be ordered from a number of supporting vendors to convert to H-4 headlights.
You should be able to order the GM Euro wiring harness and lenses from a dealer to take care of making the rear lights function properly. Just make sure that you order the GM wiring harnesses for the rear as the harness from most vendors will function like mine.
I hope this helps.
-Rob
As my Vette is a US spec car, it has the reversing lights either side of the rear license plate. Therefore, I can use all the lower segments of the tail lights for indicators as you have done.
My main concern is I need to know if making these alterations can affect the wiring resistance in such a way that it can screw up other electrical functions controlled by the cars computers (such as the Active Handling, ABS, Selective Damping etc). Who did your conversion work and did you have any electrical functional problems afterwards? If a garage/dealership did your conversion work, do you know whether they re-programmed any of the computers?
Brian
http://www.corvettegarage.com/produc...78661bb4c7c051
http://www.ecklers.com/product.asp?d...FBEMJ4MP6TDX5B
http://www.ecklers.com/product.asp?p...FBEMJ4MP6TDX5B
