Blackhawk or VaraRam
Old Oct 17, 2004 | 07:11 PM
superx101's Avatar
superx101
1st Gear
Default Blackhawk or VaraRam
I am looking for some help in which one to choose. Blackhawk or VaraRam.
Old Oct 17, 2004 | 07:34 PM
Scubanme's Avatar
Scubanme
Vararam
Old Oct 17, 2004 | 09:10 PM
noel48's Avatar
noel48
St. Jude Donor '14
Originally Posted by Scubanme
Vararam
Old Oct 17, 2004 | 09:12 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
No question Vararam
Old Oct 17, 2004 | 09:23 PM
Mitch C's Avatar
Mitch C
I have had both systems on my car. The Vararam is a cold air system and will give you better performance. The Blackwing is a non cold air system that is not quite as good performance wise but you will be less likely to have water ingestion issues. Both systems are good it just depends on what you want. I currently have the Vararam on my car.
Old Oct 17, 2004 | 09:35 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
I think you mean "Blackwing". Both are good but you have to be a bit more concerned with possible water ingestion issues during or after severe rains with the cold air systems.
Old Oct 17, 2004 | 09:42 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
St. Jude Donor '03-'04-'05-'06
superx101,
VARARAM VR-B2!!!!
We are actually running them on sale so this may just be the right time for you and everyone else to get in on this.
Check out this thread for more info:
http://forums.corvetteforum.com/showthread.php?t=927869
From seeing before and after dyno testing results from the Vararam, I can honestly say that it will be VERY DIFFICULT if not impossible to find a better intake system over the Vararam. The Vararam is the only aftermarket intake that showed 20 degree cooler MAF temp readings. This gives you an efficient cooler running set-up which is ALWAYS good.
Shawn
Old Oct 17, 2004 | 09:53 PM
SR-71's Avatar
SR-71
I like my vararam pretty well
Old Oct 17, 2004 | 10:55 PM
Ron H's Avatar
Ron H
Old Oct 18, 2004 | 01:32 AM
90 droptop's Avatar
90 droptop
Vararam
To Blackhawk or VaraRam
