Need some Rocker Arm advice...
Old Oct 18, 2004 | 09:33 AM
P-Colavette's Avatar
P-Colavette
Default Need some Rocker Arm advice...
Hello !
I am going to be installing some CarTech Stage 2 heads/cam package (Thank's for the deal Corvette Poor!) on my '99, and I need to know if my stock LS1 rocker arms will work, or should I step up to some aftermarket rocker arms ? The package as purchased from Corvette Poor includes Hardened pushrods, and the heads are complete, minus the rocker arms. Thank's for your help in advance,
Steve
Old Oct 18, 2004 | 09:38 AM
XTrooper's Avatar
XTrooper
Your stock rocker arms will work just fine.
Old Oct 18, 2004 | 12:15 PM
frodo84's Avatar
frodo84
Uneducated autodidact
Default he's right, they will work fine
It's true that the stock rockers will work fine, the only reason I will use aftermarket (harland sharps) when I do my H/C is the chance that one will come apart (known issue with them) and dump the needle bearings into the engine. Search here and at ls1tech.com to get an idea of how often that happens...just my opinion.
Old Oct 18, 2004 | 01:09 PM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Stock rocker arms will work fine as long as they dont have a whole lot of miles on them. If they have over 60K-70K miles on them, I would consider going with something else. Its not purdy when one of the stock ones dies and dumps its nice little needle bearings throughout your motor.
Old Oct 18, 2004 | 02:04 PM
gojo's Avatar
gojo
Harland Sharp also will rebuild your stock rockers so that the bearings won't come apart.
To Need some Rocker Arm advice...
