Car Stalled - Trouble starting
Old Oct 18, 2004 | 09:39 AM
GR8-LIFE's Avatar
GR8-LIFE
Default Car Stalled - Trouble starting
Signs of this problem started happening 3 weeks ago. To make a long story short 3 weeks ago I washed the car and immediately after washing it, she would not turn over. Plenty of juice, just wouldn't turn over. Then 20 minuets later, she started no problem.
Yesterday same thing. Car wasn't driven since Thursday and I go to start her and again, plenty of juice, but doesnt turn over. So I start moving some wires, thinking there is a loose connection somewhere but still no luck. Then eventually she starts.
So I'm driving her and remember stepping on the gas just a little and she just kinda lost power and kinda coasted to a standstill. As she was dying, I tried to start, pop the clutch but nothing. So with my flashers on and the car just sitting, I tried to start her but I have the same thing happened earlier in the day - she wouldnt turn over. Then I tried starting her and she sounded like she wanted to turn over, almost did, but then died agian. I tried a few more times and eventually she started.
Sound like a fuel injection issue or fuel pump issue maybe? I would say bad gas but thats highly unlikely since this has happened on different tanks of gas.
I'll check for codes later tonight. Any ideas?
Old Oct 18, 2004 | 10:56 AM
GR8-LIFE's Avatar
GR8-LIFE
ttt
Old Oct 18, 2004 | 12:43 PM
Ruby6spd's Avatar
Ruby6spd
Active Streak: 90 Days
Sounds like a ground issue.. probably in your fuel pump or maybe a problem with you injectors
put a test light on the injector wires when you turning it over to see if they are pulsing. That would be a good place to start.
Old Oct 18, 2004 | 01:24 PM
GR8-LIFE's Avatar
GR8-LIFE
Thanks for your help. I'm working with a new shop now - no more dealer if I can help it. I'm awaiting for DRM ducts to arrive so they can install them. I'll offer up your suggestion on this issue when I bring her in.
To Car Stalled - Trouble starting
