Will shorter shocks help a lowered C5???
Old Oct 18, 2004 | 11:29 PM
Davesredvette's Avatar
Davesredvette
Default Will shorter shocks help a lowered C5???
I have heard if you lower a C5 far enough the shocks will actually hit the bump stops and not have any suspension travel. That said, it would seem shorter shocks would return some of the lost travel.
I have read posts of modifying the shock brackets to essentially re-position the upper limit of travel. I have also read of guys buying shorter shocks and bolting right in. Problem solved!!
New, shorter shocks would be my preference but I haven't seen any advertised as "shorter" than stock. Anyone know if shorter shocks would actually return lost suspension travel and if so, where to get them.
Thanks,
Dave
Old Oct 18, 2004 | 11:34 PM
CNB's Avatar
CNB
Bilsteins are supposed to be shorter. That is what I have and my car rides very good. It still hops a little over sharp bumps but my car is low.
Old Oct 19, 2004 | 01:18 AM
Paras's Avatar
Paras
True, Bilsteins are shorter but if DavesRedVette wanted to go really low, I'd be interested to know if there's shorter shock options in addition to the Bilstein. I have Bilsteins as well but is it possible that something shorter than a Bilstein could provide the same amount of travel in a shorter overall body? Or are there perhaps several models of Bilsteins which are different sizes? (Hopefully, I've asked the right questions to help the author of the thread.)
Old Oct 19, 2004 | 10:41 AM
CNB's Avatar
CNB
Koni Sports (orange) are 3/4" shorter then stock.
Old Oct 19, 2004 | 01:45 PM
Davesredvette
Yup, just trying to find out whats out there and what other people have done.
Thanks,
Dave
Old Oct 19, 2004 | 02:39 PM
QS-ZO6's Avatar
QS-ZO6
Default Lowered C5 Shocks
I know that we have mega lowered several C5's, most of them running the Bilstein shocks. We have had nothing but good luck with them. The set runs $399. Give me a call at the shop at 281-870-8787 if you have any questions.
Old Oct 19, 2004 | 03:38 PM
vettethret's Avatar
vettethret
Thanks,
Dave
Call Craig at WCC. MY car is lowered 4" with coil overs. He had bilstein custom make a 2" shorter shock body for increased travel. I think it was only about $50 extra. This is the best way to go as it will still bolt right in.
Old Oct 19, 2004 | 03:51 PM
Paras's Avatar
Paras
That's awesome! But how do you clear speed bumps & dips? I hated life in So. Cal. only being lowered only 2 inches! (from my experience Laguna is a much friendlier place for lowered cars, no doubt...)
Old Oct 19, 2004 | 04:03 PM
vettethret's Avatar
vettethret
Ipretty much drive the same route all the time. I know it's impossible to believe but I dont scrape a whole lot. I just ordered the same splitters as ALLKAR so that might change!
Old Oct 19, 2004 | 04:07 PM
curtbriggs's Avatar
curtbriggs
Do you have any bump steer issues? If not were the tie rods and steering modified as in lowered or were the steering arms modified?
Old Oct 19, 2004 | 04:10 PM
vettethret's Avatar
vettethret
In my CAR EVERYTHING is modified. I do have the bump steer it from Baer though. No bump ster to speak of.
Old Oct 19, 2004 | 04:39 PM
Fast one's Avatar
Fast one
If the upper steel mounts are reversed you can gain 1/2" but don't the shocks limit the upward wheel travel? I had Bilsteins and the tires were just hitting the tops of the wheel wells so shorter shocks would be worse. If the ride height is lowered 4" there can't be much upper wheel travel left.
Old Oct 19, 2004 | 04:52 PM
curtbriggs's Avatar
curtbriggs
Mike, I looked your car up, impressive!
Cheers, Curt
Old Oct 19, 2004 | 05:08 PM
vettethret's Avatar
vettethret
Cheers, Curt
Thanks Curt. I've got a ton of dough just in suspension so I've been through the ups and downs on what works and what doesnt.
Old Oct 19, 2004 | 06:14 PM
Davesredvette
Ya, I know coil overs are the hot ticket but just a little over budget. I checked the Bilstein web site and didn't see anything other than generic C5 shocks. They have a couple different firmness models but no mention of shorter length. Sounds like they can make what ever size I need from your post.
Thanks,
Dave
Old Oct 20, 2004 | 01:49 PM
2kbluestreak's Avatar
2kbluestreak
I lowered my Z51 2" in the rear at the same time I added Bilstein Sports, and it would bottom out at 70mph at a certain dip in the road. Boy, it would really bounce me out of the seat. So then, I reversed and modified the upper shock mounts, gaining .800" by measurement. When I hit that dip again, the rear suspension didn't bottom out anymore, but the O.D.'s of the tires slightly rubbed on the inner fenders. So, I think I've found the boundaries for a lowered Z51. To prevent further rubbing,
I raised the rear a half inch.
Old Oct 20, 2004 | 02:32 PM
Paras's Avatar
Paras
Would stiffer springs have kept you from bottoming out?
To Will shorter shocks help a lowered C5???
Old Oct 20, 2004 | 06:25 PM
Davesredvette
Ya, that's what I'm afraid of, bottoming out at the track going 125...What all was involved with modifying the shock bracket?
Thanks,
Dave
Old Oct 21, 2004 | 09:30 AM
2kbluestreak
The rear upper shock brackets are steel stampings shaped like a football with rounded points. They have a stiffening lip on the down side, while the top side is flat where it seats against the frame and inner fender. You really do not want to simply flip it around so that it seats on the stiffening lip. Some guys have ground off the lip, but this weakens the mount plate. What you should to is shim the face so that the lip has a little clearance with the frame surface. A lot of guys have simply stacked washers so they are thicker than the lip. I had some 1/4" aluminum handy, so I cut 2 little triangles for each mount plate that fit inside the lip in the corners, then drilled holes to match the holes in the mount plate. This gains a little surface area over washers for better support of the mount plate. The Bilstein sports have a small bushing on their shafts that the lower washer seats against. I used a lathe to short these by .100", which gained me the same amount of raising the end of the shock rod.
Old Oct 21, 2004 | 09:19 PM
Davesredvette
Thanks 2Kbluestreak, I really appreciate it. I think I will give it a go this weekend!!!!
Thanks again,
Dave
