Here's the dyno results from Eddie's 00 Z28 Magic Stick & LS6 Intake Install.
Eddie can jump on here & tell us about his mods, but here's is the results from adding the Magic Stick & the ls6 intake
Not a bad gain for just two mods & a tune
How do Fbody and C5 dyno #'s usually compare? I always thought Fbody typically pulled slightly bigger #'s diue to the drivetrain differences...right or wrong?
From: IF YOUR BIG DOLLAR PROJECT DOESN'T RUN 9'S OR BETTER ....BURN IT ! SHUT YOUR MOUTH AND GRAB A LANE ! CHICAGO IL. -------- HOME OF THE FASTEST STREETCARS BARNONE !
they are very similar, the g5x3 and rev 3 are very close in duration and lift, but the rev 3 is slightly larger, so it must likely will make more power, they are both cimp cams i believe so you know they have aggressive lobes
I know this has been asked before, but I'll ask again: Will the MS3 work with the PRC Stage II Heads without flycutting?
Also, would the MS3 be too much for a daily driven street car A4 with a 3500 stall and 3.42s? Or would I need a 4000 stall and/or 3.73s? It looks like a 3500 stall would suffice, though, if I'm not going to drag race.
Look at the Dyno graph. Less than 200 hp and ft/lbs of torque at 3000 rpm compared to stock at over 300 for each. I'd say, without a 3.90 rear, it would be lousy on the street.
What are you talking about? the numbers are higher at 3000 rpm.
Youre not looking at the graph right. the light red and dark red are the Before hp/tq #s. The light blue and dark blue are the After hp/tq #'s. The fastest way to identify a dyno pull on a graph showing several at once is where the hp and tq cross each other at 5250.
