changing rearend
Old Oct 19, 2004 | 10:33 PM
Nuzz's Avatar
Nuzz
Default changing rearend
I'm putting in 3.42 diff on my a4. Do I have to drop the torque tube and tranny to get the diff out? and if I were to take the tranny out, does the torque tube need to be dropped from the flywheel? thanks!!
Nuzz
Old Oct 19, 2004 | 10:46 PM
SkankZilla's Avatar
SkankZilla
This is the best info I've seen so far.
http://mikemercury.home.att.net/
Old Oct 19, 2004 | 11:59 PM
FRC Tom's Avatar
FRC Tom
This might help also.
http://www.c5frc.com/clutchinstall/
Old Oct 20, 2004 | 12:03 AM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
Not as bad as it looks. Go for it!!!!
Old Oct 20, 2004 | 06:49 AM
Nuzz's Avatar
Nuzz
thanks for the input so far
Old Oct 20, 2004 | 06:54 AM
Patches's Avatar
Patches
Buddy and I pulled his a few weeks ago. Not too bad at all.
Drivetrain R&R
Old Oct 21, 2004 | 11:46 AM
lotzahp's Avatar
lotzahp
I watched the whole process on my car, and took a lot of pix.
The torque tube doesn't need to come off, and the tranny doesn't have to come out. If you drop the exhaust and torque tube cover, you can lower the transaxle enough to unbolt the diff and slide it off the tranny output shaft. You just can't drop it down too far because the motor might hit the firewall.
To changing rearend
