Tuning...Tech 2 or LS1 Edit and Dyno?
Old Oct 20, 2004 | 07:24 PM
MikeJamesC5's Avatar
MikeJamesC5
Default Tuning...Tech 2 or LS1 Edit and Dyno?
I've been having problems with my car since I installed my LG LT Headers. We have checked the 02 sensors a million times so don't say "its probley the 02 sensors"! I've heard that a lot. I think it could be a spark plug or wire. My car feels like its missing and my brother in law hooked up a computer that said I have a mis-fire in the 2nd cylinder and it also had some other codes that I can't remember off the top of my head but he didn't know what they were. I'll check with him because he wrote it down.
Well my car probley needs a good tune anyways. So I called 2 different tuners who are vendors on this forum and 1 uses just the tech 2 and the other uses the LS1 Edit and a dyno. So I'm wondering which one would be better in my case? I know the dyno would probley be better but for my codes that are coming up would the tech 2 be better or can the LS1 edit do the same thing?
Old Oct 20, 2004 | 07:36 PM
Gordy M's Avatar
Gordy M
Normally I would recommend the LS1 edit and dyno tune, unless the one using the Tech 2 is Kellermeyer. Otherwise I would recommend Livernois motorsports or Chris at AP engineering. Regarding the codes, write them down and then do a seach for DIC Codes as there is a listing on the forum of all the codes and an explanation.
Old Oct 20, 2004 | 07:39 PM
MikeJamesC5
APE is the tuner that I called that uses the LS1 Edit and the dyno.
Old Oct 20, 2004 | 07:46 PM
Gordy M's Avatar
Gordy M
Chris knows his stuff. That would be my choice.
Old Oct 20, 2004 | 08:08 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Ls1 edit and dyno tune hands down!
Old Oct 20, 2004 | 09:21 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
I have had some issues with missing (detonation ) found that shell gas makes may car ping like crazy. Also my plugs were gapped at 35 also were NGK-TR55ix . Increase the gap in your plug switch to non iridium plugs. Worth a shot
Old Oct 21, 2004 | 02:59 AM
mdhmi's Avatar
mdhmi
Mike I know it is a hike for you but you would likely benefit heavily by having Kurk @ APE (their tuner - also does the tuning for W2W) tune your car. Personally I would do a cam swap to make the $500 tune worthwhile.
Good luck,
Mark
Old Oct 21, 2004 | 08:17 PM
MikeJamesC5
Good luck,
Mark
What cam to use if I plan on getting the D-1 Procharger?
I should just have him install the AFR 205 Heads.
Yeah, the cost for a full tune about made me sh_t myself. I believe it was $535. It is a hike but thats were I'm going Wednesday.
Here is the code or codes my car read:
1571 TCS PWM CIRCUIT FREQ SIGNAL
By the way Mark what is W2W?
Old Oct 21, 2004 | 08:33 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
First of all, you cant tune a car with a Tech2. Its a diagnostic scan tool, not a programmer. If someone says they are going to tune your car with a tech 2 they have no clue.
Old Oct 21, 2004 | 08:41 PM
MikeJamesC5
Yeah, I know its a diagnostic tool but I believe it was Rod or Rob at Specter Werkes told me thats what he would use. But he also said he only had 90 days in there. Thats why I was scared to take it there because they were going to charge 80+ dollars an hour on top of the cost of parts if needed and this guy is pretty new there and he said he was going to be working on my car. They could have had it for who knows how long.
Hey Chris what heads and cam would your recommend for your D-1 Kit?
Old Oct 21, 2004 | 09:29 PM
mdhmi's Avatar
mdhmi
... By the way Mark what is W2W?
Wheel to Wheel.
Mark
Old Oct 21, 2004 | 09:35 PM
Gordy M's Avatar
Gordy M
The tech 2 can do limited programming and flashing of the PCM. However, it is limited to the EPA paramaters and the knowledge of the user. They can also reset PCM's and update the PCM. LS1 edit and HPTuners can change over 100 parameters. If you have a stock engine with limited bolt ons the tech 2 will do. Danny Kellermeyer uses it to set up TCC corvettes for SCCA racing. S/C and injected cars, head and cam cars, etc, usually use LS1 or HPT for better tuning.
Old Oct 21, 2004 | 10:55 PM
F1_SS's Avatar
F1_SS
1. In your other post i also only thought the tech 2 was a diagnostic tool so this confirms my original thought.
2.If your going to do a charger later (soon) i would say to wait and tune it all at once, some tuners will charge you for retunes.
3.I dont think any tuner will tune a car that is not mechanically stable, so you would need to get that code fix and not just try to tune the car with that code being thrown.
Old Oct 22, 2004 | 06:10 PM
MikeJamesC5
Regarding number 3.
I agree. So would I have to go somewhere that has a tech 2 or would APE be able to fix the codes?
Thats what this whole post was about. I might have messed up with the title of this post but that is exactly what I'm trying to figure out. Can I have APE fix the codes and tune it or should I go to Specter Werkes first and have the codes fixed and then go to APE? Or should I go to a dealer? I would think the dealer wouldn't want to work on my car because its not under warranty and I have aftermarket parts on it. I'm more concerned about the codes right now because my car runs like boo boo.
Old Oct 28, 2004 | 05:57 PM
TurboLX's Avatar
TurboLX
Actually, with the right software on your computer and a CAT5 connection you can do a COMPLETE (over 3000 parameters available) flash of any GM PCM through the Tech2. However, this software isn't commercially available the way LS1_edit, HPTuners, etc are.
Old Oct 28, 2004 | 06:17 PM
Sack Rat TT's Avatar
Sack Rat TT
The best use of Tech 2 is in conjunction with LS1edit on the dyno and then the highway. Tech 2 will note misses, knock retard, injector pulse width, IAT, etc so that the correct changes can be edited into the PCM for additional runs to determine if the needed changes took effect and in the desired direction. The Tech 2 tells the tuner where to go with LS1 edit by data gathered on each dyno run. THEN, take Tech 2 in the car on the highway and verify good tune, no knock retard, fuel trims etc. The load on the motor on the highway is not the same as on the dyno and once again Tech 2 will grade the quality of the tune. Good Tuning takes time. Good Luck.
Old Oct 28, 2004 | 06:32 PM
mdhmi's Avatar
mdhmi
Mike,
Take your car into APE to diagnose the problem. You first need to figure out why your car is throwing codes. Perhaps it is something minor and you can get away without a full dyno tune.
Good luck,
Mark
To Tuning...Tech 2 or LS1 Edit and Dyno?
