Headlight problems, please help!
Old Oct 21, 2004 | 12:59 PM
Optimus's Avatar
Optimus
7th Gear
Default Headlight problems, please help!
Headlight problem
I am experiencing a strange problem with the headlights. It started when my headlight would go up with a delay. When I turn the switch on the steering wheel, the headlights would come up on the random 3, 4, 6 minutes later. Than I they stopped coming up at all. I thought a bad switch on the steering wheel. However once I started lifting them up manually, they would react to closing, and than again started coming up on random. Today they feel like coming up every time I turn the switch, but when I close them, the left one makes a cracking noise for a couple of second. So naturally I think the gears on the motor is bad. But why the delay? Could I have a bad motor in conjunction to some other problem? Relay or Switch? or the bad motor doesn't allow response to the headlights? Another weird thing, when I lift them up manually they still turn on at random. Any help is much appreciated.
Thanks!
Old Oct 21, 2004 | 10:28 PM
splash's Avatar
splash
You might want to first check the battery post and make sure they are tight with a wrench. If that checks out good and you still have the same problem you have a bad switch as with alot of people on this forum but I haven't found a good work around yet so good luck.
