Defective cag defeat
Old Oct 22, 2004 | 07:44 PM
cuspid's Avatar
cuspid
Default Defective cag defeat
My check engine light came on so I checked for codes and I had p0803 1-4 upshift solenoid. After some research I found several people have had this with there cag defeat. I did the resistor mod for 99 cents and no more codes or check engine light. I took the cag defeat apart and there was no resistor inside. My $20 bought 2 wires leading to a plug of silicone. I don't know how it functioned for 6 months. I bought it from one of the leading corvette catalogs don't remember which one. I'm probably not the only one who will have this problem.
Old Oct 22, 2004 | 10:48 PM
Shortimer's Avatar
Shortimer
Thanks for the update. I saw a post on the simple/cheap fix with the resistor and was giving it some thought.
Old Oct 22, 2004 | 11:00 PM
pinot's Avatar
pinot
Yeah, the bypass is only a temp fix. Mine was giving the same erratic code even after I replaced the resistor. Just tune it out with LS1 and throw out that POS.
To Defective cag defeat
