Left Side Multifunction Switch Replacement
Just one question -
Did you really have to pull the steering wheel?
I'm looking in the service manual and thinking that it could be done without pulling the wheel. Just a battery disconnect and pull the airbag fuses.
Yes/No?
As an addition, it looks like it can indeed be done with the steering wheel still installed...so far.
The two torx-head bolts holding the upper trim cover on were a surprise. Thank someone for the needle-nosed vise-grips I bought to install my shifter.
Another thing...don't you HATE getting into your car, and finding out someone else was in there first... and didn't do a good job / put everything back like it should be? Yeesh...
Otherwise you can't get the lower screw out of the switch without pulling the wheel.
I've used up my luck for today now.
