Dead Battery
Old Oct 23, 2004 | 06:45 PM
cor4vette1's Avatar
cor4vette1
Default Dead Battery
Went to start the car this morning *******DEAD BATTERY********* It is a 2004 with 2500 miles. Called roadside they came and jumped the car. I checked i did not leave anything on. I took the car for a drive came home shut it off it restarted tryed this about 4 times. Put a battery tender on.if there is a short the battery tender will never fully charge the battery. I feel if the battery is bad that it would not have restarted the car. I checked for codes there were none.I don't know if there is a code when the battery is bad. Is there anything else i should check?.
Old Oct 23, 2004 | 07:20 PM
RWhite's Avatar
RWhite
My battery went out after a little over a year. Replaced it with a Red Top Optima from Auto Zone.
It should last a lot longer than the OEM. My dragster also has the same battery.
I have never had much luck with the stock batteries. They usually last me 2-3 years max.
Old Oct 23, 2004 | 07:27 PM
rickvette's Avatar
rickvette
Question- How long did the Corvette go unused? The factory Delco's without a battery tender are good for 17-21 days (parasetic drain). I also changed over the Optima Red Top long time ago and have never had a problem since! In fact, my Optima was purchased in 1999 and is on its 2nd C5!
Old Oct 23, 2004 | 08:25 PM
cor4vette1's Avatar
cor4vette1
I had it out Sunday and drove about 50 miles. On thursday i started it after changing the oil. Right now the battery tender been on it since 4pm it should be fully charged by the morning. If not Monday I can get a battery tester.
Old Oct 24, 2004 | 10:22 AM
carpe dm's Avatar
carpe dm
Some batteries will not charge well after a total discharge. A Battery Tender is good to maintain a battery, not to charge one. It may work, but is probably not good for it. Hope it works out for you.
To Dead Battery
