Tranny/Converter Issues After New Cam Install
Anyway, I'm pretty sure they're related to the size of the cam and the perceived misfires created by it. Anyone know of a fix? Thanks!
However, I want to know what the fix is so I can do it myself as I'm purchasing the HP Tuners software in the very near future.
P0748 indicates a continuous open or short to ground on the pressure control solenoid valve circuit. Hmmm...
The P1870 test only runs when the gear selector is in 'D' and TCC lockup is commanded, so only in 4th isn't too surprising. You can relax the test's RPM threshold limits, but you shouldn't have to - since it only runs when the TCC is commanded on you should be seeing minimum slippage (i.e. near 0) at that point.
Couple of thoughts... The service manual indicates P0748 may set in a low voltage situation. Beyond that as a potential cause, I'd look for bad/loose connections, particular those that have been apart recently. One further thought is that your programming may have line pressure too high under some conditions which I think could cause this as well. Alternatively, the PCM commands max line pressure in response to P1870 so I suppose it's possible the source of your PC solenoid code. (If this is the case, it would mean your tranny really is slipping internally.) You should be able to monitor tons of related OBD-II parameters with a scan tool, in particular the slippage. That parameter is only an esitmate but if it gradually gets worse it would suggest a non-electrical issue. OTOH, if the tranny funny business is really just a result of the misfire detection logic, there's a bunch of good info over at LS1Tech.com regarding how to disable that. However, I would only expect that to be an issue at lower RPM though and not a very likely source of issue.
Would be useful for you to have some info about your programming:
1) Changes to misfire tables
2) Changes to force motor current tables
3) Changes to your MAF table
4) and maybe changes to your TCC apply/release tables.
Now, the $64K question... Did this happen before or after the trip to the strip?
http://www.ls1tech.com/forums/showthread.php?t=162767
You might try disabling misfire detection altogether using the (easy) heavy-handed method first. If that clears it up, spend the time to zero in with some more selective values to get at least some detection back.
Wouldn't hurt to get the freeze frame data with your codes if possible. Curious to know which came first.
If nothing else, I'll either solve the problem this way or better know what I'm dealing with through the process of elimination. As I said in the other thread, I've no problem with buying a new, race-prepped tranny, but I don't want to unless it's necessary as I just can't see tossing my present one if it's still in good working order.
of time between firing events. The overlap of the cam causes
variation in crankshaft speed. This is detected as a possible
misfiring cylinder or possibly a rough road condition. The computer will lock and unlock the torque converter going from
a fluid coupling to a mechanical lock-up to try and determine
if the condition is an actual cylinder misfire or a drivetrain, or
rough road condition. This builds heat! (Not Good)!
It also looks at ckp (crankshaft speed versus input to trans)
efficiency. You can fix with LS1 Edit by going to low rpm misfire
counter tables and putting 32767 in all cells. I would move the
lock-up to only lock-up in 4th gear at cruise speeds. Lower
the force motor amps to increase the pressure reducing friction
in the trans - Iam a trainer for techs 20 years
I'd go with a Yank C5 SS3200. I'm on my third Yank converter now (had a TT2800 and later an ST3500 in my '99 Camaro SS) and I've always had good luck with them.
The SS should be nice improvement w/o getting real loose.
Hope it's these easy ones and not the PO748.
). Anyway, that's what was causing all the problems. I drove all the way home in OD (around a 1.5 hour, 75 mile run) and I'm happy to report the converter locked up normally and stayed locked and NO CODES!
Thanks for all your help, fellas. Just to be double-sure, we checked each and everyone of the possibilites listed here in the thread to be certain nothing was missed or amiss. Thanks again for everyone's help!
