Lobe separation angle?
Old Oct 26, 2004 | 08:33 AM
3Vettes@Home's Avatar
3Vettes@Home
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Default Lobe separation angle?
one other ? Providing the cam duration and lift are the same, what differences would a cam with 112 LSA and one with 114 LSA be?, which one would have more lope, driveability issues, etc?. (running a 6spd) Thanks
Old Oct 26, 2004 | 08:37 AM
6Speeder's Avatar
6Speeder
The 112 would lope more at idle, be harder to get through smog, but have more mid range torque.
Old Oct 26, 2004 | 08:39 AM
Patches's Avatar
Patches
Lobe separation angle is the number of degrees separating the peak lift point of the exhaust lobe and the peak point of the intake lobe. I'm running a 112 LSA on my MN6 and the lope is more pronounced than on a larger LSA cam such as the 114 you mention. The smaller the LSA, the more overlap in the valve events and the more negative effects on emissions. A smaller LSA tends to shift the power peak down in the RPM band.
You can see how the LSA comes into play in the intake-exhaust valve event interaction in the illustration below.
Old Oct 26, 2004 | 08:44 AM
CR555's Avatar
CR555
The 112 LSA does not idle as well as the 114 LSA camshaft, but it will produce better power in the mid-range. If emissions compliance is a concern, the 114 LSA is the better choice.
3Vettes@Home
Cruise-In V Veteran
Thanks 6speeder and Patches! This is what I was looking for, Patches, as always you give much information to this forum
Old Oct 26, 2004 | 08:45 AM
3Vettes@Home
Cruise-In V Veteran
Thanks I want the rougher idle
Old Oct 26, 2004 | 08:57 AM
Patches's Avatar
Patches
My car has the signature shake or buck at idle. It's either love it or hate it. I've gotten the and a big grin at stop lights when guys look over to see my vette dancin'.
Old Oct 26, 2004 | 05:05 PM
3Vettes@Home
Cruise-In V Veteran
I hear ya! That's what I want "Dancin' Vette"
Old Oct 26, 2004 | 06:50 PM
Scubanme's Avatar
Scubanme
Yep, Patches has taken the time to send me info on a clutch install.
Darn nice of the guy to help out.
Old Oct 26, 2004 | 07:47 PM
3Vettes@Home
Cruise-In V Veteran
I agree...that's what keeps this Forum going strong
Old Oct 27, 2004 | 01:06 AM
Cunningham Motorsports's Avatar
0Cunningham Motorsports
Former Vendor
i got the g5x3 on a 114, and even it shakes alot at idle
Old Oct 27, 2004 | 02:13 AM
Face's Avatar
Face
If you have a cam with a lot of duration, even if it's on a 114 LSA, it will shake the car. Check out the idle video in my sig, it's a 230/236 114 cam.
Old Oct 27, 2004 | 07:22 AM
3Vettes@Home
Cruise-In V Veteran
Now there you go, Nice video! Thanks guys! I ordered 232/240 595/608 112 cam (G5X2) from LG, they said it will lope more than the 114. still running stock heads at the moment, but at least when I get ready to change them, the cam will already be in place.
To Lobe separation angle?
