Head lights come up at different times
Old Oct 26, 2004 | 07:51 PM
C5JONNY's Avatar
C5JONNY
Default Head lights come up at different times
What the title says, is there an adjustment? When I turn on my lights they are not coming up at the same exact time, the left comes up slightly before the right.
Old Oct 26, 2004 | 08:25 PM
vetty's Avatar
vetty
if one side is going higher than the other then check the gears to see if theyre both in the same positions, if not it may just be that one is getting power before the other... maybe a short somewhere?? just an idea
Old Oct 27, 2004 | 01:09 AM
C5JONNY's Avatar
C5JONNY
One is not going up higher than the other, they are just not timed right.
Old Oct 27, 2004 | 02:11 AM
Face's Avatar
Face
Could be the module.
Good luck!
Old Oct 27, 2004 | 09:05 AM
Gimmesum HP's Avatar
Gimmesum HP
Mine did that and it turned out to be the plastic gears and a rubber piece inside the headlight motors. You can buy a rebuild kit that will fix it for about $75 bucks for both headlights. I was only gonna do one light but I'm glad I did both since the other one was about to go too.
To Head lights come up at different times
