Mods done, results inside
Old Oct 26, 2004 | 08:07 PM
vetterlatethannever's Avatar
vetterlatethannever
Default Mods done, results inside
Well, all my so far planned mods are done and all my money is gone , so without further adue, here are the results: Stock with just a halltech stinger my car dynoed 319 RWHP. I was actually happy with that. I had a cam, underdrive pulley, LT headers with high flow cats and even a LS6 intake. Before the LS6 was put on the car did 371 RWHP and after the intake it was 375. To be honest I was expecting more, I would appreciate everyone to comment and please don't hesitate to ask any questions.
For the record: car is a 2000 6-speed and was computer tuned(not dyno tuned).
Old Oct 26, 2004 | 08:57 PM
rob&dalevance's Avatar
rob&dalevance
Sounds pretty good. I would think you would have gotten a little more out of that intake, but maybe not.. What kinda Cam are you running?? Thats about the same set up I am putting in mine.
Old Oct 26, 2004 | 09:43 PM
vetterlatethannever
Running the MTI G1, a little "lopey" for me, should have done the stealth, but hindsight is 20/20 they say.
On that intake - I though I would get more too, I was told @ 15hp but only got 4..... They forgot to do it(the intake) and dynoed it before, then put it on and dynoed after so i know it is just from that intake. I can try a vid for sound of that cam, if interested, let me know.
Old Oct 26, 2004 | 09:46 PM
George8211's Avatar
George8211
What are the specs on the cam?? Duration, Lift?? Did you upgrade your valve springs?? Pushrods??
Old Oct 26, 2004 | 11:33 PM
vetterlatethannever
Specs for the G1 are 228 232 .588 .575 113. I also did the Valve springs, titanium retainers and hardened pushrods.
Old Oct 27, 2004 | 12:06 AM
jrose7004's Avatar
jrose7004
Congrats on your mods!
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
looks like your are being held back with the LS1 heads. you cam wants air! try a set of Z06 heads or AFRs. youll make over 400rwhp easily!
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
looks like your are being held back with the LS1 heads. your motor wants more air! try a set of Z06 heads or AFRs. youll make way over 400rwhp with a good tune easily!
Old Oct 27, 2004 | 12:20 AM
George8211's Avatar
George8211
You've got some potent parts there...
You have some untapped potential still by replacing the heads. Your not using all of your cam. What you have is kinda like trying to breathe threw a 50 ft garden hose.
The stock heads are also holding back your intake... your not realizing all the benifit because the heads are flowing less air then the intake can provide.
This is just a guess... (there will be about 12,430 opinions on these numbers). Add your stage 3 heads and you should be around 420-430 hp.
Old Oct 27, 2004 | 02:28 AM
mdhmi's Avatar
mdhmi
Congrats on your numbers. Time for some tuning.
Mark
Old Oct 27, 2004 | 04:10 PM
vetterlatethannever
So would it be worth the $$ to dyno tune? Does the Computer tune need to be done (with the dyno tune) or did I waste the $$ on the computer tune, should I have gotten the dyno tune instead?
To Mods done, results inside
