AFR H/C dyno : Video
The car before h/c had a VaraRam, p&p TB, LS6 manifold, 28.8lb injectors, Kooks w/HF cats, Kooks xpipe, Corsa Indy's, Spec Stage 3 w Aluminum fw, 4:10 gears, hardened output shaft. And I changed the rod bolts to ARP Pro's a little while ago.
We added a set of AFR 205's milled .010" mounted on Cometic .040" MLS gaskets, Comp 224/228 .581"/.588" 112 lsa @ +2, Comp 850 lifters, TR 7.400 hardended pr's, Harland Sharp 1.7 rockers, ported LS6 oil pump, JWIS timing chain, ASP UD pulley, and flowmatched 30lb/hr SVO injectors.
I only had to clearance the heads behind the rockers to get them to fit but with the beefy valve cover shoulders there was no issue.
Here is a short video of 3 of the runs. The first we didn't take it up that high because we wanted to check for things like float, etc. The next two were to 6800 rpm. I was able to get my AFR dead on at 13:1.
All I can say is the car is a really mean street machine when I want it to be and it is easy to drive when I want to cruise. Low end torque is amazing. I can pull np all the way from 1200 rpm in 4th, to 6th with no lugging. Gas mileage has improved to 34.5 mph (at 60mph on flat level road) even with the 4:10's. It has a nice little lope at idle to keep the rice away. I feel I have acomplished exactly what I wanted with this h/c package. I didn't want a race car, but I wanted a street car I could race. Thanks to Tony @ AFR for the help and suggestions, and to Brian, Trevor, and Jason from TSP for answering all my questions and accomodating me changing my order 3 times and still getting it right, And to Matt, George, and Nick at TTP for all the help and suggestions at the tune. Check out the video.
TTP Dyno
i now have a stupid question for you Roger..since i am a newb...(5 mnth with my vette)how much it would cost (more or less) to have my car at that level?mine is a stock MN6 with magnaflow cats and x pipes.....
thank you...
How do you like the Spec III? I'm shopping for clutches.
how did you like the service at TTP?
BTW, even though it's much easier to get sideways now, I keep the TC on when driving on the street.
What I probably am going to do will be in the spring will be to remove the heads and have them milled the extra .014" to bring up the compression and when I do that I will add an LSX & NW 90mm and port match it with the heads off or an LS2 and TB depending on what that setup has yet to reveal.
I am looking at this as a work still in progress so yes, I am very happy with the results I have gotten so far.
