LS6 Intake Q's
Old Oct 28, 2004 | 07:12 PM
vetracn98's Avatar
vetracn98
St. Jude Donor '08
Default LS6 Intake Q's
I just bought an intake off a fellow member, but was reading around about possible other parts I need. Is this true, or can I just take the LS1 1 intake off (1998 A4) and throw the other one on????
Old Oct 28, 2004 | 07:26 PM
Mike52's Avatar
Mike52
I think you need some kind of air hose as well. Im planning on doing this on my '98 so hopefully someone will answer you.
Old Oct 28, 2004 | 07:50 PM
C5JONNY's Avatar
C5JONNY
Im pretty sure you need 2 plugs, and some kind of hose or pipe. Sorry I dont know the exact parts, but I know they are cheap. Maybe call GM parts direct, they'll know. Im sure somone else will chime in with the exac specs.
Old Oct 28, 2004 | 09:45 PM
JAY KOCH's Avatar
JAY KOCH
Check out JMX's site; http://www.ls1howto.com/index.php?ar...d0614a8c613167
Great stuff.
Old Oct 28, 2004 | 09:59 PM
vetterlatethannever's Avatar
vetterlatethannever
Yep, You'll need parts. They aren't priced bad though.
Old Oct 29, 2004 | 09:38 AM
PurpleHaze98's Avatar
PurpleHaze98
You need 2 plugs to go in the rear coolant tubes. One pipe off a LS6 intake car with a hose that goes to your throttle body I believe I just did this mod 2 weeks ago. Also before you do this if your doing it yourself. Take a air compressor and blow out around the injectors really really really good. So no rocks fall into the cylinders when you do this. Pm me if you need anymore help
To LS6 Intake Q's
