Rhino Ramps
Old Oct 29, 2004 | 08:30 AM
spdnman's Avatar
spdnman
Default Rhino Ramps
If I use Rhino Ramps to raise the rear of the Vette, what do I need to do for safety? Just back up onto them and chock the front wheels? Thanks. Adam
Old Oct 29, 2004 | 10:04 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
You got it!
Old Oct 29, 2004 | 10:35 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Where did you get your rhino ramps and how much.
Old Oct 29, 2004 | 10:53 AM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
Here is a trick that I can't take credit for, but it works great!
Tie a piece of rope (about 24" lg) to the end of each ramp. Lay it straight out towards your car. Now drive over the rope and onto the ramps. This will keep the ramps from sliding while you are driveling up the incline.
Old Oct 29, 2004 | 11:00 AM
Busa196's Avatar
Busa196
Pep Boys- about $30.00
Old Oct 29, 2004 | 11:15 AM
The Batman's Avatar
The Batman
I never drive up my Rhino ramps, but I do drive off of them. I jack up the car from either front or rear crossmember, kick the ramps under the wheels, then drop it. Done!
Old Oct 29, 2004 | 03:34 PM
srchief100's Avatar
srchief100
Thanks for the cool tip/trick I'll give ya credit for this one!
Old Oct 29, 2004 | 05:34 PM
MassaRusty's Avatar
MassaRusty
I picked up my rhino ramps at advance auto for $25. You can't go wrong with that.
To Rhino Ramps
