Trying to install new pedal and instructions say use old spring but I'm not sure how the spring positions. Of course, it just poped out when I removed the pin from the original pedal. Can anybody provide information? Thanks
The pics didn't want to show automatically for me when I went there a few moments ago but they were there. You may have to right click on each pic (red "X"), then on Properties and then copy and paste the URL for the pictures in your browser to get them to show.
The trick is to make sure you bend the spring to let the new screw go though. And learning to work while standing on your head.
Good Luck, they look good once installed.
Thanks to both of you. I'm 6'2'' and almost 220lbs so it is a challenge to fit under the dash. I really appreciate the information and will hopefully will have them installed before the Jaguars and Houston kick off tomorrow.
