Need to replace my battery...
Old Oct 31, 2004 | 05:17 PM
prospero63's Avatar
prospero63
Default Need to replace my battery...
The battery in my 03 Z06 has gone to better times, so I need to replace it. Went to autozone and picked up an Optima RED75/35 battery. Now for the tricky part
I'm a computer geek. I can fix damned near anything related to a router, switch or firewall. What I can't do is fix a car So, how should I disconnect, remove, replace and reconnect the new battery? Here is what I think I should do:
1) Disconnect the ground.
2) Disconnect the positive.
3) Remove the battery
4) Put new battery in
5) Connect the positive
6) Connect the ground
Is that correct? On a side note, I have a AAA membership I have all but forgotten, so I'm calling them to come give me a jump so I can get it out of the damned garage
TIA
Old Oct 31, 2004 | 06:00 PM
maximum bob's Avatar
maximum bob
Yes you are correct with 1 - 6, but always be careful never to short out the two battery terminals with anything metal like a wrench. Or just get the AAA guy to do it.
Old Oct 31, 2004 | 09:15 PM
prospero63's Avatar
prospero63
Thanks!! It all went smooth.
Old Oct 31, 2004 | 11:00 PM
Shortimer's Avatar
Shortimer
Good going on the battery swap. You're gonna like that red top!
Old Nov 1, 2004 | 01:21 AM
EHS's Avatar
EHS
One year on a battery? You must have a lot of computers and routers hooked up to your Z06.
To Need to replace my battery...
