Need wiring advice for WB Sensor
Old Nov 2, 2004 | 08:37 PM
Corpsvette's Avatar
Corpsvette
Veteran: Marine Corps
Default Need wiring advice for WB Sensor
THe general jist is I am about to install my WB sensor. THe sensor must be turned on during engine running to prevent ruining it. I was thinking I could wire to a 12 volt source, like accessory, that would turn the sensor on a few seconds prior to the engine starting. It has to be 12 volts. Anyone have an easy suggestion inside the car that would provide this. THanks,
Jim K.
Old Nov 3, 2004 | 07:16 AM
wrustywrench's Avatar
wrustywrench
I wired my PLX unit to the accessory leads in the passenger foot well, its switched by , hot only when key is on...remove the mat, and the floorboard panel and you can get to the wires....should work ok...
Old Nov 5, 2004 | 12:42 PM
Corpsvette's Avatar
Corpsvette
Hey Rusty,
Okay, which wires ? Thanks,
Jim Kay
To Need wiring advice for WB Sensor
