What is the difference between "long" and "short" blocks? Are there long and short ls1's? What about ls6's. Any information will be appreciated. Thanks.
The terms "long"and "short" blocks apply to all motors for all cars.
A short block is just the block and internal part for the block (crank, pistons, rods, rings and bearings). It might have an oil pump,timing gears&chain,and cam depending on the builder.
A long block has all the components of the short block plus heads,lifters,pushrods,rockers.
