I have just finished dyno tuning last week. I am at 452 rwhp/411 rwtq @ 13.0 A/F. My mods are: AFR 205's @ 11.0 CR, G5X3 cam (on 114 lsa), Kooks 1 3/4 O/R w/ 3" pipes thru stock Ti's, stock TB and intake, 4.10 rear, K&N FIPK air charger intake, and an Excedy Dual Disc clutch.
AFR 205cc heads + AFR 224/228 cam. This is ours from Bowling Green. I don't know what my hubby did with the one with more tune which shows 9 or 10 more TQ
I have 176 more miles to break-in the diff/trans but we should be ready to run again on Friday at the private track day. We will be doing track tnt to see we me need to make any changes to the tune prior to the 12/4 track day
AFR 205cc heads (66cc)
FMS 228/230 114lsa cam
90mm intake and TB
LG long tubes
Vararam
Meziere WP
435rwhp, 405rwtq
someone esle's car (pd000)
well my car wasnt done to full potential. as we speak im milling the heads to 60cc,having the intake port matched, setting my quench tp .037 with cometic gaskets and having tea work a little magic on my heads too. so maybe ill get up with the big boys after all
Good Luck with it! Let us know how it turns out.
As for my numbers... My car had the stock mufflers, stock water pump, and stock intake
AFR 205cc heads + AFR 224/228 cam. This is ours from Bowling Green. I don't know what my hubby did with the one with more tune which shows 9 or 10 more TQ I have 176 more miles to break-in the diff/trans but we should be ready to run again on Friday at the private track day. We will be doing track tnt to see we me need to make any changes to the tune prior to the 12/4 track day
You need to have your tuner turn off the COT.
Phil
Ok what is COT? I have never heard of that abbrev.
COT is Cat Overtemp. It is a setting to protect the cat. converters from overheating and melting...Basically the computer dumps fuel. He is saying this because of the sudden dip in your A/F ratio up top in the RPM range.
If you analyze the curve very closely @ 4800 the COT starts adding fuel and you can see the HP curve flatten out. IMO it will cost you 10-25rwhp. What is your compression ratio?
Phillip
Phillip
Thanks for the info I'm not the techie of the family. I buy the stuff and it's his job to install it. I'm guessing that we can turn the COT off with LS1.edit?
Our compression ratio is 11.5
