Rear end identification
Old Nov 3, 2004 | 03:56 PM
jackson01's Avatar
jackson01
Default Rear end identification
I'm trying to determine which rear-end I have in my '01 coupe. The Production options sheet that I have shows the GU2 code to be the 2.73 rear end. I have a GU2 code on the glovebox sticker. The sheet shows the MXO code to be the M-30 Auto and says includes the G92 Performance Axle. My glovebox sticker lists the MXO code. Does this mean the 3.15 rear end comes with this tranny? Or since the rear end code listed on the glovebox sticker is GU2, then I have the 2.73 rear end? Thanks in advance for any help. Hope I explained this well enough to make sense.
Old Nov 3, 2004 | 08:03 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
get under the rear and look at the tag on the upoper right hand corner of the differential case. Then you will know for sure what you have.
