How are they holding up?
Old Nov 5, 2004 | 09:11 AM
GRRRRR8!'s Avatar
GRRRRR8!
Default How are they holding up?
I have an 01 Z06 with 69,000 miles. It still has the original clutch and, believe it or not, the original brake pads!
I haven't raced it (officially) but I don't baby it either.
Just curious about what experiences owners of the 97's to 2000 vettes have had as far as clutch life, longevity of the LS1/LS6 engines, remaining drive train components, etc.
Old Nov 5, 2004 | 09:13 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Well I won't be much help
I have a 00' with 8300 miles and an automatic, runs like an 04'
Old Nov 14, 2004 | 12:01 PM
GRRRRR8!'s Avatar
GRRRRR8!
ttt
Old Nov 14, 2004 | 01:02 PM
fhturner's Avatar
fhturner
I'd be interested to hear responses on this as well. My 2000 coupe has ~71,700 miles on it, and Friday night I first noticed what I believe to be the widespread "clutch-sticking-to-the-floor" problem. I don't know if it is the same issue, but twice now, when I've wound it up pretty good in 1st gear, the clutch pedal gets to where I only feel resistance at, say, the bottom third (or less) of travel. Normally, I might feel resistance over 80-90% of travel, with the top part having a little slack in it. It also becomes very hard to get enough clutch movement to shift gears, and it's especially hard to ease off from a stop. This doesn't just happen and go away, either-- it continues to do this even if I take it very easy after the initial occurrence.
Old Nov 14, 2004 | 02:42 PM
dmc1007's Avatar
dmc1007
Cruise-In I Veteran
Interesting question...I have a Y2k car with 51K. I still have the original brake set up and the brakes are as strong as they were 5 years ago when I purchased the car. Ditto for the clutch.
Old Nov 14, 2004 | 03:48 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I just changed out my clutch b/c GM was re-building my rear end and had all the junk out of the way. My stock '01 clutch w/ 39,000 miles on it looked great when pulled out. I changed it b/c of athe labor savings.
As for brake pads I dunno b/c I road race it and change 'em a bunch.
Old Nov 17, 2004 | 09:20 AM
GRRRRR8!'s Avatar
GRRRRR8!
These replies don't sound bad at all! Nobody has indicated wide-spread trouble of any kind. Thanks.
Old Nov 17, 2004 | 09:34 AM
VetteDrmr's Avatar
VetteDrmr
120K+ miles, 2 years of autocrossing, a few track days, and the only thing I've had go wrong was a weld breaking on the intermediate pipe where it joins to the mufflers.
Nothing in the drive train, suspension, brakes, etc. Obviously I'm replacing brake pads, but even the rotors are holding up well. Change out the engine oil 3 times a year, flush the brakes every year and bleed every 3 events, tranny and diff fluids once a year, etc.
HTH, and have a good one,
Mike
Old Nov 20, 2004 | 09:44 AM
GRRRRR8!'s Avatar
GRRRRR8!
Thanks,
Anybody else?
Old Nov 20, 2004 | 10:43 AM
waymirec's Avatar
waymirec
My '99 FRC still has the original clutch and brakes @ 65k miles. The clutch is still fine, but the brakes just locked up on me a week or so ago. Just in time for the new Brembo's
Old Nov 20, 2004 | 10:50 AM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Car has 150,000 miles on original drivetrain, clutch let go at 135,000. Only issue with the motor is a self inflicted pressure loss from some engine work I did.
Old Nov 20, 2004 | 11:43 AM
Bat Boy99's Avatar
Bat Boy99
Over 70,000 mile for me. Still have the stock clutch and brakes. The only thing I have changed is the tires.
To How are they holding up?
