Looking for any tips on intake manifold install
Old Nov 6, 2004 | 04:49 PM
juriah's Avatar
juriah
Default Looking for any tips on intake manifold install
I just replaced the oil pressure sensor for the second time. First time I let some one else do it. Now to make sure no short cuts are taken, I am doing is myself. Manifold came out pretty easy, less one or two vacuum hoses. I check for dirt in the manifold and in the ports leading to the valves. Cleaned the aluminum surface that meets intake manifold. Do I need to replace the gaskets ? About 50 % of the people I talk to say yes and 50 % say no. Whether I change them or not, Do I need to lubricate them with anything. Everything else looks good no coolant leaks. I need to get a couple of connectors; one vacuum and on electrical. Should not be a big deal. Any tips on cleaning this area before I put it back together. I am just using window cleaner for now.
Old Nov 6, 2004 | 07:08 PM
pdd000's Avatar
pdd000
check out ls1howto.com
Old Nov 6, 2004 | 08:16 PM
T_Vert's Avatar
T_Vert
ive had my intake off a few times w/o ever replacing the gaskets. I just wiped everything down as they are o rings and dont need a perfect surface. You dont need to lubricate the o rings for a good seal.
dave
Old Nov 7, 2004 | 08:40 AM
juriah's Avatar
juriah
Great web site. Excellent illustrations and descriptions
I am not going to change the gaskets. There is no problems now, no reason to create one.
Thanks guys for the help
Old Nov 7, 2004 | 09:02 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
dave
but I did put a light coat of vaseline on them just so they would slide a little easier into position
To Looking for any tips on intake manifold install
