vert window seal adjustment
Old Nov 6, 2004 | 06:41 PM
donnyonee's Avatar
donnyonee
Default vert window seal adjustment
99 c5 vert-
does anyone know the link or ? to adjust the window rubber seals, especially the right rear verticle 1?
ive got way too much leakage.
thanks!
don
Old Nov 7, 2004 | 12:17 PM
Kenny94945's Avatar
Kenny94945
Some of the seals can move back and forth on their tracks (so to say).
Also some of the tracks can bend inward and out ward.
For that vertical seal you mention, I recall there is one screw or push pin and one could insert some weather striping behind it as an experiment. Or bur a new seal.
However, make sure you have supple weather stripes (w/s) by applying die electric grease to them.
Lastly, most air leaks are solved with a window tip in adjustment. Search for the instructions. If you can remove a door panel you can do a tip in! Very easy.
Old Nov 7, 2004 | 01:49 PM
robl45's Avatar
robl45
mine leaks like crazy at the left front. I'm going to try the tip in method when I get a chance otherwise its going to a professional top shop. Just remember one thing, at least on my car, chances are, if you fix one leak on one side, you'll end up with a leak on the other side.
To vert window seal adjustment
