Gauges shutdown
Old Nov 7, 2004 | 10:06 AM
97vette's Avatar
97vette
Default Gauges shutdown
This is wierd. All guages including speed, tach, lites, stopped functioning. I pressed the reset button and all things stopped. In the display there is a series of AAAAAAAAAAAAAAAAAAAAAA what would cause this?
Old Nov 7, 2004 | 08:19 PM
timfoster's Avatar
timfoster
I experienced the same problem when I replaced the battery. Try pulling fuse 16 & 23 engine compartment and disconnect the battery for a few minutes and then reconnect the battery with the fuses pulled. Replace the fuses and turn the key to the on position to see if the trouble goes away.
Good luck and let me know if this works.
It worked for me.
Old Nov 9, 2004 | 09:55 AM
97vette's Avatar
97vette
Default gauge problem
yes it was a bad battery
thanks
To Gauges shutdown
