Valve spring help...Please
Old Nov 7, 2004 | 10:37 AM
3Vettes@Home's Avatar
3Vettes@Home
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Default Valve spring help...Please
New cam installed yesterday! Fairly easy install until I got to the springs. The spring compressor I have (pic below) will not compress both springs (dual springs) Without buying the rocker type recommended by Thunder racing, LG Motorsports, what tool have you guys used? Many thanks, I am now at a point where I can't do anything else.
my spring spring tool..won't work
cam and underdrive pulley installed
Thunder racing tool $129.00 !!!
Old Nov 7, 2004 | 10:57 AM
MTWallet's Avatar
MTWallet
That spring compressor will work just fine. Just use it as if there isn't an inner spring and when the main spring is squeezed, just push down a bit and the inner spring will compress, its a pretty light spring. I used the exact same compressor for mine and it worked great.
Old Nov 7, 2004 | 11:10 AM
3Vettes@Home
Cruise-In V Veteran
MTWallet...That's what I did, but could hardly compress and install locks...maybe it's because I'm using comp 921 dual springs? they are stout!
Old Nov 7, 2004 | 02:00 PM
BlueRag's Avatar
BlueRag
Default Valve Spring Tool
I have three different tools I've used over the last 6 years, and this is the best one I have for changing springs on an LS1:
http://ls1tech.com/forums/showthread.php?t=95463
I have replaced four spring sets with this tool (3 times on a Corvette, and one time on a Tahoe). Well worth the money....
Old Nov 7, 2004 | 02:24 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
the VHP spring tool will do 2 springs at once. even duals. designed specifically for the LS1.
http://www.vincihighperformance.com/superwebdeals.HTML
Old Nov 7, 2004 | 03:27 PM
John's vette's Avatar
John's vette
Cruise-In III Veteran
Have you tried to rent one from your local auto parts store? I would hate to spend $100+ for something you use once every year or two.
Old Nov 7, 2004 | 03:51 PM
see5's Avatar
see5
Yes, this one ^^ is stupid simple and works better than my expensive one.
Old Nov 8, 2004 | 03:53 AM
van1's Avatar
van1
If I were you, Id go with the simple tool. It looks like its winner.
Old Nov 8, 2004 | 10:09 AM
frodo84's Avatar
frodo84
Uneducated autodidact
Default Larry tool....it's great
I just bought one, for only $40 you can't beat it.
Old Nov 8, 2004 | 10:24 AM
XTrooper's Avatar
XTrooper
The new one from Crane works great!
I got mine from Thunder Racing.
http://www.thunderracing.com/catalog...&vid=7&pcid=17
To Valve spring help...Please
