Steering column lock confusion, need help.
1. Install a CLB module which you can purchase from Corvettes of Houston for $49.95 http://www.corvettesofhouston.com/
2. Build your own for less than $25 which you can see my plans at the following link: http://shelor.net/Z/CorvetteForum/Cscokd/
3. Install the (GM) "harness K"
All three of these solutions do the same thing in that they fool the BCM.
But if you have a MN6 you should definitely be pro-active because the column will lock up on you eventually and you'll need to be towed.
John
