NGK TR55's or TR6's?
Old Nov 8, 2004 | 01:17 PM
Laguna Blu's Avatar
Laguna Blu
Default NGK TR55's or TR6's?
If not boosted or running juice is there any reason to run TR6's? I currently run TR55's and I am experiencing a rough cold idle start but that may be more due to tuning than the plugs. Anyone use both and have some real world experience to share?
Old Nov 8, 2004 | 02:41 PM
Laguna Blu's Avatar
Laguna Blu
Anyone?????
Old Nov 8, 2004 | 03:00 PM
SideStep's Avatar
SideStep
Old Nov 8, 2004 | 05:03 PM
FKING1's Avatar
FKING1
Running 55's for over 2 yrs in my cammed & mod'd 00 with good results and no start problems.
FredK.
Old Nov 8, 2004 | 05:15 PM
3Vettes@Home's Avatar
3Vettes@Home
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
I've been running TR55's for almost 2 years...no cold start problems here...gapped at 55 I believe. Sorry haven't used the others.
Old Nov 8, 2004 | 06:44 PM
Laguna Blu's Avatar
Laguna Blu
Will probably go with the 55's again.
Old Nov 8, 2004 | 06:57 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
I have tr55s and gapped at .055 no abnormal cold start problems here either
Old Nov 8, 2004 | 07:19 PM
Laguna Blu's Avatar
Laguna Blu
I'm convinced that my idle issues are not plug related. I'm just looking for comparos between the 2 plug types.
Old Nov 8, 2004 | 11:47 PM
Laguna Blu's Avatar
Laguna Blu
ttt
Old Nov 9, 2004 | 01:57 AM
Cunningham Motorsports's Avatar
0Cunningham Motorsports
Former Vendor
tr6s would only make your cold start issues worse, being a colder plug, stick with the tr55s, i have been using them with no issues
Old Nov 9, 2004 | 05:42 AM
Patman's Avatar
Patman
I put in TR6s in my C5 because I needed a plug change badly when I was getting it dyno tuned (the OEM plugs were giving me 7 degrees of KR!) so I had no choice. After only 2000 miles and one bad traffic jam I developed a very slight miss at idle. Swapped them out for TR55s and all is well.
I ran TR6s for a while in my 98 LS1 Firebird too, and they fouled out badly in just 13k. The engine would misfire so bad above 5000 rpm at that point that I thought the fuel pump was toast.
Old Nov 9, 2004 | 07:07 AM
itsonlyairandfuel's Avatar
itsonlyairandfuel
Went to tr6 as per ngk tech suggestion, for detonation problems. Has been running fine, It idles great and always idled until oil hits 120-150 degrees. Maybe some idle issues are tuning related. No problems here will stay with a colder plug, I have a stock engine Ron B.
Old Nov 9, 2004 | 11:06 AM
Laguna Blu's Avatar
Laguna Blu
Anyone know who has the best prices on the NGK's and MSD wires? Would like to order ASAP.
Old Nov 9, 2004 | 01:27 PM
TorchRedRaider's Avatar
TorchRedRaider
summitracing.com
order wires last month, have invoice in my desk
MSD's were $50.95 + 8.95 sh
Old Nov 9, 2004 | 01:53 PM
Laguna Blu's Avatar
Laguna Blu
Originally Posted by TorchRedRaider
summitracing.com
WCC is advertising the MSD wires for $89.95?!!! $40 more than Summit? Insane.
To NGK TR55's or TR6's?
