Basic X-Pipe Question
Old Nov 10, 2004 | 10:23 AM
MacA1979's Avatar
MacA1979
Always Shiftin'
2025 C7 of the Year Finalist - Modified
2024 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (stock)
Default Basic X-Pipe Question
I did a quick search and didn't find the answer I was looking for, so sorry if this has been discussed before!!
I have a basically stock '99 6 spd coupe. I have installed the B&B PRT exhaust. The rest of the exhaust system is stock. Right now I don't plan to install headers or change the current cats (not enough mod money ). However, I do want to purchase a good X-Pipe to eliminate the "slightly" annoying burble/popping that is associated with the B&Bs.
My question: Can I purchase and install an x-pipe that doesn't require cutting and welding anything?
Thanks!!
Old Nov 10, 2004 | 11:03 AM
Flintstone's Avatar
Flintstone
You need to cut the stock h-pipe aft of the cats with any x-pipe setup. That is a solid piece from the manifolds to the cat-back.
Magnaflow and Corsa have decent pipes for under $300, and any exhaust shop can do the work - piece of cake.
F
Old Nov 10, 2004 | 11:06 AM
NPh2005's Avatar
NPh2005
First, I think they all require some kind of welding/cutting to install.
Here's what I did. Usually I will do mods myself to save money--installed cat-back in my garage. After doing some research I found out it was cheaper to have X-pipe installed at a local muffler shop. I went to the Magnaflow website, found a dealer in my area and had them order a X-pipe and weld it in place. The difference is that it is just the X-pipe w/o the extensions and flanges like you would buy if you were going to do it yourself. If you go to the website, you'll see what I mean. Except this is welded in and only cost me $160.00 parts and labor. My 2 cents. Good luck.
Old Nov 10, 2004 | 05:19 PM
MacA1979's Avatar
MacA1979
Always Shiftin'
I thought I read somewhere that one of the manufacturers has a flared end that could be slip fit over the existing pipe (I guess this would be the cut location?) and clamped on. Is this an adequate attachment option? Or is the consensus that the X-pipe should be welded in place?
Old Nov 10, 2004 | 05:31 PM
jrose7004's Avatar
jrose7004
I bought a used Corsa X-Pipe on the parts for sale section for either $150.00 or $175.00 something like that!
Old Nov 10, 2004 | 05:34 PM
MacA1979's Avatar
MacA1979
Always Shiftin'
Have you installed it yet? If so, did you do it yourself? clamp or weld?
To Basic X-Pipe Question
