Question about mounting stock fog lights
Old Nov 10, 2004 | 02:53 PM
NONO5.0
Guest
Posts: n/a
Default Question about mounting stock fog lights
I bought a set of stock fog lights with the stock brackets a few days ago and want to mount them on the car, however, I noticed where they go on the car that there's a hexagonal hole for them to mount to.
http://www.z06vette.com/gallery/dat...ocation1new.jpg
What kind of bolt goes through there? It doesn't look like I could easily put a regular bolt through the opening and attach a nut to it due to space. Can anyone shine some light on this?
Old Nov 10, 2004 | 03:56 PM
ragtopws6's Avatar
ragtopws6
Those are called "PIN" by GM. Group # 0.293 and part # 12558081 list for $1.50 each but comes in packs of 5. These are collapsable nuts (once you tighten them in the hex hole, they will be secure). GM has a special tool to collapse these but you can make your own by using nuts and a washer (make sure the pin is in the hole before tightening). Hope this helps.
Old Nov 10, 2004 | 04:53 PM
NONO5.0
Guest
Posts: n/a
Thanks A LOT for the info!
To Question about mounting stock fog lights
