Rear Bumper Cover removal
Old Nov 10, 2004 | 04:00 PM
a6fan's Avatar
a6fan
Default Rear Bumper Cover removal
I need to remove rear bumper cover. Anything special I should watch out for?
How do I get started? Is it a straight forward job?
I know I could figure it out eventually but there's a ton of you guys out here who've done it many times and I thought I'd ask first!
Old Nov 10, 2004 | 04:04 PM
Patches's Avatar
Patches
1. Remove the tail lights, license plate, and back up light assembly.
2. Remove the 4 or so plastic plugs under the fascia, just above where the exhaust tips exit.
3. Reach up through the area where the license plate was and disconnect the plug to the 3rd brake light. Also remove the plasic clips that hold the taillight wiring to the fascia.
4. Jack the car and remove the rear wheels. Then remove the 4 or so bolts holding in the rear wheel well liners. You don't have to remove the whole thing, just enough to get your hands back there.
5. There are 2 bolts just under the side marker lights. Then there are 2 nuts directly behind the side marker lights towards the back of the car.
6. Reach through the outermost tail light holes an remove the 2 or three remaining bolts. On the right side, one of the bolts holds the ground wire for the lights and antenna.
7. Remove all of the bolts along the top edge where the hatch closes.
8. Carefully pull the bottom of the fascia towards you, then slide your fingers under the top edge at the hatch and pull up and back. The fascia just sort of "hangs" on the car like a coat on coat rack.
9. I did the job myself , but you might want to have somebody help you because the fascia is like a wet noodle when not attached to the car.
10. Lay it down on a blanket or drop cloth to avoid scratching the paint.
11. Re-install is simply the reverse of the removal process.
Old Nov 23, 2004 | 12:57 PM
brock71's Avatar
brock71
Default Rear Bumper COver Removal
Great timing. I'm ready to remove the cover on my '88. Teh bolts along th etop edge referred to in step #7 above....how do you get access to them?
John
Hudson, OH
Old Nov 23, 2004 | 01:09 PM
Patches's Avatar
Patches
You'll see them when you open the hatch.
Old Apr 3, 2019 | 01:41 PM
emarkovits's Avatar
emarkovits
Cruising
What year of car was these directions written?
Old Apr 3, 2019 | 02:47 PM
Smoken1's Avatar
Smoken1
If you are referring to Patches post it's an 02 Z06
Old Jul 12, 2019 | 07:34 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
To Rear Bumper Cover removal
