New DTC Code, need help!! 1281
Old Nov 10, 2004 | 10:14 PM
projectnightmare's Avatar
projectnightmare
Default New DTC Code, need help!! 1281
I received a DTC code of C1281 this morning on the way to work - I've read what the code means - DTC C1281 Steering Sensor Uncorrelated Malfunction .
But what the heck is it and what's the fix?
Old Nov 10, 2004 | 11:16 PM
99 The Hard Way's Avatar
99 The Hard Way
I had a similar problem with my 01 Z06. The steering shaft has a sensor mounted right near the firewall that monitors steering shaft position. It uses the input for active handling, and probably some other things. I can't recall if it's the same code I had. My sensor was bad & a new one solved the problem. You have to drop the column to replace the sensor. Hope I could be of some help. SCOTT
Old Nov 10, 2004 | 11:25 PM
Mike Mercury's Avatar
Mike Mercury
sometimes you get these codes along with the 1281:
c1286 sterring sensor bias malfunction
c1288 steering sensor circuit malfunction
Old Nov 10, 2004 | 11:30 PM
C5JONNY's Avatar
C5JONNY
I get that code all the time. It sets off my active handling when going straight. After I reset it my car immediatly goes to active handling warming up, then its fine. It only seems to happen when its cold out.
Old Nov 10, 2004 | 11:34 PM
projectnightmare
Thanks for the replies,,
My car doesn't have active handling, would it still trigger this DTC?
Old Nov 11, 2004 | 09:42 AM
ProDesign's Avatar
ProDesign
Duncan Electronics (division of BEI Technology) makes the steering sensor and the following links give a description of how system works:
http://www.sensorsmag.com/articles/0200/28/main.shtml
and
http://www.beiduncan.com/html/produc...e.htm#overview (scroll down to steering sensors)
Old Nov 11, 2004 | 10:28 AM
Als98C5's Avatar
Als98C5
I had this code. Whenever I was driving straight, the steering wheel would be off by a few degrees. A front end alignment solved the problem and straightened the steering wheel.
To New DTC Code, need help!! 1281
