Switch Power for a 2004
Old Nov 11, 2004 | 11:27 PM
Corpsvette's Avatar
Corpsvette
Veteran: Marine Corps
Default Switch Power for a 2004
I am still trying to find a switched power source for my 2004 so I can wire my WB. Just so you know before replying, the 04's do not have the switched wires in the BCM area. I am looking for possibly a colored wire off the ignition (some mentioned yellow but I didn't see it) I am not the greatest with a voltmeter. Please, anyone with a 2004 manual or someone who has discovered a switched power source please help. I am getting desparate. Even better if you have pictures. Thanks,
Jim K
Old Nov 12, 2004 | 11:11 AM
georgec114's Avatar
georgec114
Jim K
First question...What's a WB?
There are available fuses next to the BCM. Pull the cover off and
see what's there. I didn't do it but was suggested by another member.
I tapped my RD (radar detector) into the rear view mirror connector.
...George
Old Nov 12, 2004 | 11:18 AM
Corpsvette's Avatar
Corpsvette
Hey George,
WB is O2 Wideband sensor. More accurate for reading your air/fuel mixture than the narrowband sensors that come with the car.
When you say look at the fuse box and see what's there I gotta laugh and tell you fuses. J/K. What should I look for? Do I need to pull out the voltmeter and see which fuses are hot only when the key is turned to the run position. I did discover the post last night about the rearview mirror. I may see if I can trace that down and make it work. Thanks for any other help you can give. I guess I should have also mentioned it needs to be 12 volts just like the cigeratte lighter.
Jim K.
Old Nov 12, 2004 | 11:32 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Pink
Old Nov 12, 2004 | 11:34 AM
Patches's Avatar
Patches
Posted this this morning. Pick a switched circuit and add this.
http://forums.corvetteforum.com/showthread.php?t=946719
Old Nov 12, 2004 | 05:30 PM
Corpsvette's Avatar
Corpsvette
Dang Patches, what the heck took you so long. Been waiting for an answer for almost 12 hours. Geeez. That looks pretty awesome but will PM you because I have more question as it is what I am looking for I think but not sure how the heck to put it in. You da man.
Jim K.
To Switch Power for a 2004
