lighting
Old Nov 14, 2004 | 12:53 PM
worldtraveler's Avatar
worldtraveler
From: Proud dad of 2 responsible adults and 1 fallen warrior txtx
Default lighting
Has anyone gone to both Piaa 1100x fogs and the xtreme white plus bulbs? If yes, did you change out both high and low?
Old Nov 14, 2004 | 01:03 PM
cmb396's Avatar
cmb396
CI 7-8-9-10 Veteran
I'm getting ready to change out hi and low bulbs in about 20 minutes. I'll let you know tonight how they work.
Old Nov 14, 2004 | 01:56 PM
KKu77's Avatar
KKu77
You probably wouldn't need to change out the high's because the fog lights are switched off when the high beam is on.
On a side note, I had the Xtreme white H4 bulbs with the PIAA 1100x's and while the match was better than stock, the 1100x's made even the xtreme white's look a little yellowish.
Old Nov 14, 2004 | 06:45 PM
worldtraveler
Hey, thanks for the feed back. For the price it seems like a simple decision to go with the full change out. I was wondering if there was much change in the high beams.
Old Nov 18, 2004 | 10:36 AM
worldtraveler
Hope the lights are working. Haven't seen any pic's yet.
To lighting
