Intermittant buzzing
Old Nov 15, 2004 | 08:33 AM
DocToss's Avatar
DocToss
Default Intermittant buzzing
I have just noticed an intermittant buzzing coming from the interior rear,? side. It only happens when I press the gas pedal and the car is moving. I just had the dealer do the column lock recall. The car is a 2000 a4. Any suggestions? The noise is brief, lasting about 2 seconds each time it occurs, but stops immediately when I let up off the gas.
Old Nov 15, 2004 | 09:34 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Is it coming from the driver's side? If so, it is most likely the fuel pump (annoying but harmless).
Old Nov 15, 2004 | 09:46 AM
atl97vette's Avatar
atl97vette
From: You want HOW much for that Corvette part??? Atlanta GA
sounds like the fuel pump
Old Nov 15, 2004 | 10:51 AM
DocToss's Avatar
DocToss
Wouldn't you hear the fuel pump under the hood and not toward the rear?
Old Nov 15, 2004 | 11:10 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
No. The pump is located forward of the driver's side rear tire.
Also, here is a thread on another forum which might be relevant:
http://www.fatherlarryscorvetteshop....=1321#post5014
Old Nov 21, 2004 | 11:25 AM
DocToss's Avatar
DocToss
I believe I will take it back to the dealer and see what they think. Anyone else notice any noise from the fuel pump after the factory column lock and relay fix? The car seems to work ok, and I have had good service and trust the service at this dealer.
To Intermittant buzzing
