Running lamp out
Old Nov 15, 2004 | 11:44 PM
jaygood's Avatar
jaygood
Default Running lamp out
How do you change out the running lamp?
Old Nov 16, 2004 | 12:03 AM
lanceg1041's Avatar
lanceg1041
I just did mine with the help of Bob(16Again), jack up the front and remove the small access panel (5 screws) under the light. Push aside the brake cooling duct and you then can get access to the bulb. Some people suggest lifting the headlight and removing the bezel, then snaking your hand in there to get the bulb. I tried that and couldn't squeeze my hand through the opening. It should only take about 15 minutes.
Old Nov 16, 2004 | 10:55 AM
JOHN MOORE's Avatar
JOHN MOORE
i removed the headlight bezel and went at it from the top...got the tip from a local tire/muffler shop that services a lot of vettes in the area...
To Running lamp out
