Front Calipers on rear conversion...
Old Nov 16, 2004 | 05:46 PM
Nitro-C5's Avatar
Nitro-C5
Moderator
St. Jude 15 Year Donor
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '08-'25
Default Front Calipers on rear conversion...
who has done this? I currently have the Bear Eradispeed plus 1 14" rear rotors. I want to use my fronts in the rear and upgrade the fronts to 6 pistons. Has anyone done this before? Is there a braket that can be made to accomodte the bigger calipers on the back?
Old Nov 16, 2004 | 06:53 PM
Patches's Avatar
Patches
Mean Green did the conversion on his first vert.
Old Nov 16, 2004 | 07:50 PM
FreddyG's Avatar
FreddyG
Here you go Rick. I thought about doing the same thing and made a .pdf when Mean Green posted the pics. I hope that it helps!
Rear/Front brake conversion...............
Speaking of Mean Green, that's a GREAT Halloween costume in your avatar!
Old Nov 16, 2004 | 09:03 PM
Nitro-C5's Avatar
Nitro-C5
Moderator
Cruise-In V Veteran
Thanks for the heads up
Old Nov 16, 2004 | 09:05 PM
Nitro-C5's Avatar
Nitro-C5
Moderator
Cruise-In V Veteran
Very instructions thanks alot Does anyone know where to get a brake bias kit?
BTW: I have to laugh everytime someone says that I'm wearing a cool costume. That's actually me at the 2000 Mack Truck Worlds Strongest Man contest with my fiancee. One of the boys in OT got a hold of the pic and photochopped me green..I thought it was so I used it as my Avatar
Old Nov 16, 2004 | 09:53 PM
dads01dream's Avatar
dads01dream
Great avatar, I knew you were... ummm.... big! But I thought you simply colored yourself green for some kind of Halloween party.
Old Nov 17, 2004 | 12:41 PM
Nitro-C5's Avatar
Nitro-C5
Moderator
Cruise-In V Veteran
Can anyone on here confirm that front calipers can fit on Eradispeed Plus one rears with 18" rims?
Old Nov 17, 2004 | 12:45 PM
dmtnt's Avatar
dmtnt
St. Jude Donor '03-'05-'06 & '12
Nitro, Doug Rippie makes a larger master cylinder that has a brake bias valve on it. Some guys who have swapped fronts onto the rears have reported too long of a brake pedal travel - the bigger master fixes this.
Old Nov 17, 2004 | 01:01 PM
FreddyG's Avatar
FreddyG
You're Very welcome!
Old Nov 17, 2004 | 04:58 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Make sure you do not need a operational parking brake for inspection.
Old Nov 17, 2004 | 05:29 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
So no parking brake anymore? Guess it won't really matter as the stocker don't work too well
Rick where you been man! Hope all is well w/ the torn muscles etc.
Cya
Old Nov 18, 2004 | 04:19 AM
c5inphila's Avatar
c5inphila
Hi, your front brakes are 1 1/4 " thick, the eradispeed rears are 1 " thick. If you use the front caliper you must use the front rotor , and you will lose the parking brake. walt
To Front Calipers on rear conversion...
