Flat Tire (non-runflat)... patch or plug??
Old Nov 16, 2004 | 10:46 PM
jo8243's Avatar
jo8243
Default Flat Tire (non-runflat)... patch or plug??
What's best for a non-runflat tire... patch or a plug and why?
Seems like a patch is more durable but the tire has to be removed and remounted. Seems like that would stress the bead/sidewall some. Are plugs reliable enough to use or should I get a patch?
Old Nov 16, 2004 | 10:50 PM
3Vettes@Home's Avatar
3Vettes@Home
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
even if it's not a runflat, it still is speedrated and should only be patched, and if the hole (if I remember) is larger than 1/8" the tire is compromised according to some manufacturers, and is no longer safe at higher speeds.
Old Nov 16, 2004 | 10:51 PM
99 The Hard Way's Avatar
99 The Hard Way
I always patch it unless i am stuck or nothing is open. If it were my work truck, i might plug it, but my vette would get a patch
SCOTT
Old Nov 16, 2004 | 11:38 PM
VetteTech81's Avatar
VetteTech81
I would replace the tire.. why risk it at high speed.. but if you have to repair.. DO NOT USE A PLUG.. they are horrible.. and tend to leak. I would highly reccomend using a patch. but only repair if that is the only option.. like I said don't risk having a tire fail on you with a corvette you might do more damage then what it's worth to save a hundred or 2..
-=Rick
Old Nov 17, 2004 | 01:23 AM
GrayC5's Avatar
GrayC5
Puncture Repairs the Right Way
Old Nov 17, 2004 | 09:36 AM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
or just make sure your fiance's father owns his own tire repair shop... tends to work well.
Old Nov 17, 2004 | 09:51 AM
VetteDrmr's Avatar
VetteDrmr
IMO, a plug is an emergency field repair to last long enough to get the tire repaired properly with a patch. So far I haven't had to plug one of my tires, but I carry a plug kit and 12v compressor in my car just in case.
HTH, and have a good one,
Mike
To Flat Tire (non-runflat)... patch or plug??
