Largest MAF sensor ??? Conversion??
Old Nov 18, 2004 | 09:04 PM
Tomulrich's Avatar
Tomulrich
Default Largest MAF sensor ??? Conversion??
Has anyone used a Pro -M MAF for a ford with Pro-m converter so GM ECM can read air flow.
Ideas on larger than 85 mm MAF sensors?
90mm Throttle body/......want to use a bigger than 85 mm MAF.....
What do you think an 85mm MAF can flow?
What air flow is needed to support 650 - 700 flywheel HP normally aspirated?
What about MAFless tuning. good bad ?? pros cons?
This setup would be for a 427 LS motor.
Tom
